WTF is up wit this new alpine
Old Nov 6, 2005 | 05:51 PM
User56898's Avatar
i got the alpine CDA-9855 headunit and i can not get the bass to go up
I have this head unit and so does my friend and he has a 15 inch sub with 1000watts going to it but it hardly move
when we raise the volume it hits a little harder but we want what you woud expect from a older head unit (bass up and down settings)
any trick to this thing
how can i download sound settings using Alpine's i-Personalize feature
Old Nov 7, 2005 | 03:19 AM
LS1 RULZ's Avatar
Re: WTF is up wit this new alpine
Are you using the correct crossover settings and their appropriate RCA outputs?
Old Nov 8, 2005 | 02:28 PM
Mrcoffey's Avatar
I've got the same one, but I haven't experimented with it much bc I haven't upgraded my speaker system yet. Everything is still stock. You might try holding the menu button down for a few seconds to bring up the parametric eq, and adjust the individual frequencies from there.
Old Nov 9, 2005 | 08:49 PM
User56898's Avatar
i hooked everying up right
there isnt a bass raise and lower like all the other ones??
weird
Old Nov 10, 2005 | 02:49 PM
bt96ss's Avatar
It has a subwoofer control. They come set at 0. It needs to be turned up to 15. Push the volume **** till it says subwoofer then turn it up. You can also set the crossover freq and slope. That is a very good radio once you get it set.
Old Nov 10, 2005 | 06:07 PM
User56898's Avatar
did both of that...
when we put a different older radio on it the bass was amazing
Old Nov 13, 2005 | 11:26 AM
Lions3's Avatar
The problem with your Alpine deck isn't the bass adjustments, it's the weak pre-out voltage to your sub-amp. Go on eBay, pick up a decent line driver (Phoenix Gold, Audiocontrol etc..) and add that to your system. The entire Alpine lineup is **** poor for line-out voltage.
My friend has the IVA-D310 and he's using an older MTX 2300 amp hooked up to a JL 13W6v2, and he got almost nothing out of that sub even with the sub amp gain pinned (Which is a bad, bad thing). I gave him my Audiocontrol line driver, and that made a night and day difference.
Old Nov 19, 2005 | 07:17 PM
merim123's Avatar
I'm looking at this head unit and almost ready to order off of ebay. It has 4 volt pre-outs, why isn't that enough?
football4life
Oct 4, 2015 07:48 AM
surreybrad
Jul 29, 2015 02:55 PM
Collector Car
Jan 5, 2015 10:58 AM
tapout
Aug 23, 2002 10:05 AM
MadKilla
Jul 22, 2002 06:42 PM
