Wiring vs ohms pic inside
Old Oct 1, 2003 | 06:37 PM
Klypto's Avatar
well my current setup is like my pic need to copy and paste the URL into a dif browser...
http://community.webshots.com/s/imag...5xaVpSz_ph.jpg
well i dont totally under stand ohms... i think i have it set up for optimal power...
its a JL 500/1 mono stable at 1.5 ohm amp...
2 12 W3D4 (4 ohm) DVC subs....
im 80% sure thats how they are wired inside the box...
thx for all inputs...
cory see sig for real pictures of setup!
Old Oct 1, 2003 | 06:48 PM
LS1 RULZ's Avatar
We're sorry!
The Webshots page you have requested has either moved or no longer exists.
Old Oct 1, 2003 | 06:53 PM
Klypto's Avatar
HMMMMMMM well....
go to
http://community.webshots.com/user/klypto
then go to random stuff, then i think its on the 2nd page..
grr
cory
Old Oct 1, 2003 | 07:07 PM
LS1 RULZ's Avatar
It looks like you have the subs wired so that they will present a 4 ohm load to the amp. It appears in your pic that you have each sub's VC's wired in series. This makes each sub 8 ohms. Then you have the 8 ohm subs wired in parallel to the amp which presents a 4 ohm load total.
You would be better off with subs with dual 8 ohm VC's. That way you connect the VC's in parallel to make each sub 4 ohms. Then you could wire the now 4 ohm subs to the amp in parallel for a final 2 ohm load.
I don't know all the specs on your amp but usually an amp will put out a lot more power into 2 ohms than it will 4
Old Oct 1, 2003 | 07:26 PM
Klypto's Avatar
thx
how would i re-wire them to put a 2 ohm load on the amp...
thx cory
if can plz do a pos pic like i did in paint or something...
hehe
thx
Old Oct 1, 2003 | 07:58 PM
LS1 RULZ's Avatar
You can't get a 2 ohm load with the subs you have now.
Like I said above you need subs with dual 8 ohm voice coils. You would then wire them parallel/parallel for a 2 ohm load.
This is what you have now...
http://www.jlaudio.com/tutorials/wir...C_Series_2.gif
This is what you need to do but with dual 8 ohm voice coiled subs...
http://www.jlaudio.com/tutorials/wir...Parallel_2.gif
Old Oct 1, 2003 | 08:55 PM
Klypto's Avatar
so would have been better to get 8 ohm subs?
cries
either way, they still sound great 8']
Old Oct 2, 2003 | 05:29 AM
Jaswir's Avatar
i have subs that have the two connections on it would i get more power to them if i connect them like the pic below???
http://www.jlaudio.com/tutorials/wi..._Parallel_2.gif
jayvar
Feb 2, 2015 10:00 PM
rjc1629
Jan 27, 2015 10:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
omarECD
Aug 19, 2002 07:28 AM
Omega9
Aug 2, 2002 12:33 AM
