Wiring for the fog lights
I have a question about the wiring for the fog lights of my friends car, its a 95 transam. We are trying to get both fog lights to work. The problem is that currently only one fog light is connected with a set of two wires running to it, green and black I believe. Now I don't seem to find the other connector for the other fog light I don't know if the previous owner cutted it or what happen. So my question is how are both fog lights connected. Do you have just one set of wires that split in two to both fog lights coming from the same place or does each fog light has it own separate set of wires. Can anybody guide me as to where I need to look or know of some kind of manual that shows how the wiring should be. I really appreciate your help.
Re: Wiring for the fog lights
I would say it'd be pretty easy to find out.
Just go backwards up the wiring harness from the ends of the green/black wires you have found. Eventually it will T into the main harness, and you will also probably see where the other green/black wires got cut off at.
In simple form - it goes like this.
Switch---->Main Harness for fog lights---<To Left and Right Fog Lights.
Brake_L8
Jan 20, 2015 09:44 AM
30thZ286speed
Aug 3, 2002 04:54 AM
