Where EXACTLY is the body control module and what does it look like?
Old Dec 5, 2003 | 04:10 PM
Schantin's Avatar
Question Where EXACTLY is the body control module and what does it look like?
I'm installing an alarm and need to tap into a couple of the wires on the body control module. All I know is it's under the dash on the passanger side. There's all kinds of wires, etc there. A description of what I'm looking for (ie what it looks like) and exactly where under the dash it is would be very appreciated.
Thanks,
Schantin
2002 Camaro Z28 M6
Old Dec 6, 2003 | 01:22 AM
Javelin3o4's Avatar
looking at the wiring diagram for an alarm install and seeing that almost every wire is located at the BCM i would think it would be some type of box, with a few plugs going into, it says the BCM is located near the a/c blower motor, just look around and look at the wires see if any of the colors match up with the diagram.
Old Dec 6, 2003 | 03:09 AM
JasonL's Avatar
Here's the location and what it looks like on a '96. Your '02 may be different, but this gives you some idea.
http://www.bfranker.badz28.com/fbody/alarm96up2.htm
Remember you can tap the wire anywhere, not just right next to the BCM... e.g. on my car, the BCM is totally buried and I've never even seen it. But I was able to do my install by finding the equivalent wires under the passenger dash (factory service manual is a huge help here). Good luck.
Old Dec 6, 2003 | 09:06 PM
Schantin's Avatar
Thanks for the info. I got the alarm installed today. Knowing which box was the BCM was a big help
Schantin
2002 Camaro Z28 M6
dluna333
15
Mar 13, 2015 12:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
CARiD
Feb 9, 2015 09:35 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
