What ohms/load would this be?
Old May 10, 2004 | 11:41 PM
$hawn's Avatar
I have some single voice coil, 4 ohm subs, that are wired pos. to sub to pos. on amp, and neg. on sub, to neg. on amp. Is this a 4ohm load, can I wire these 4 ohm subs to play at a 2ohm load, and how would I wire it that way. Thanks
Old May 10, 2004 | 11:45 PM
Knowklew's Avatar
some? how many?
If you have (2) single 4 ohm voice coil subs you can run both sub + to amp + and both sub - to amp - and that will give you a 2 ohm load.
EDIT: AKA parallel wiring
Old May 11, 2004 | 08:06 PM
$hawn's Avatar
Yeah I have two, so if I did it that way, I would only be using 1 channel, and have an open channel, and could run two more subs together on the other channel.
Old May 12, 2004 | 11:07 PM
Mitch2067's Avatar
woah... before you wire anything up what amp do you have...
if its a two channel amp your gona wana bridge it.. if its bridgeable...
ifs its a mono, (1 channel amp) you shouldn't have any open channels..
heres a wiring wizard i use... pretty pics
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Old May 13, 2004 | 06:59 PM
$hawn's Avatar
It's a two channel amp thats bridgeable, I wasnt sure if it would be safe to bridge two subs, but I would still have 1 channel not in use that way right? Thanks for the help.
Old May 16, 2004 | 12:56 AM
$hawn's Avatar
Is this right guys?
Old May 16, 2004 | 08:17 AM
97FormulaWS-6's Avatar
You are WAY off dude...
Post up some links to the amp and subs that you have and we can tell you EXACTLY how to wire them properly.
This generic information SUCKS for telling people how to do something properly, there are so many different pieces of stereo equipment that have different limitations on them, advise given may cause you to blow something without having the proper information.
If you tell us what equipment you are using, subs and amps, we can tell you how to hook it up properly for the best performance.
Old May 16, 2004 | 06:35 PM
$hawn's Avatar
MTX TH2150X amp and 2 pioneer premier TS-W1240C single voice coil 4ohm subs.
Old May 16, 2004 | 08:10 PM
You can not bridge that amplifier safely with those speakers, if you do you will smoke it/blow it. With that equipment you're best bet is to connect 1 speaker per channel, period.
If you want more power, you're going to need to upgrade equipment.
Old May 16, 2004 | 08:15 PM
Old May 16, 2004 | 09:14 PM
$hawn's Avatar
Ok because my amp says it's rms is 75 watts, I assume at a 4ohm load right if it's hooked up pos. to pos. and neg. to neg. right? And 150 at 2ohms, so to run my amp in 2ohms I would need 2ohm subs then to keep things kosher correct? Thanks for the help.
Old May 17, 2004 | 06:28 AM
Correct.
Old May 21, 2004 | 02:41 PM
LWillmann's Avatar
He should be able to parallel wire the two subs to a single channel on the amp and not hurt the amp. Since running both subs off one channel ISN'T bridging, he should be fine.
However, he's probably only going to get the same amount of power as he would if he were running two subs at 4-ohms in stereo.
