What high powered amp?
Old Jun 5, 2003 | 09:03 PM
1KillerV6's Avatar
Arrow What high powered amp?
I'm wanting to get a really high powered amp and connecting 2 good 12's to it. I want something with really good Rms power like 400 and up. Also i'd like it to be under $200 if possible.
Old Jun 5, 2003 | 10:37 PM
firebirdude's Avatar
For that price, I would search Ebay for the Kicker Kx400.1 or kx600.1 also, the JBL BP600.1
Old Jun 6, 2003 | 12:15 AM
PaulN64's Avatar
Earthquake
Old Jun 6, 2003 | 12:59 PM
1KillerV6's Avatar
This one looks good What do u guys think?
Old Jun 6, 2003 | 01:44 PM
1KillerV6's Avatar
This one seems a good one too. 500W x 2 RMS @ 4 ohms and only $170....that sounds a little low.
Old Jun 6, 2003 | 02:27 PM
Out of the two you linked, I'd go with the Profile...... but then again I wouldn't go with either! Did you search Ebay for the amps I mentioned? I'm telling you, those are the best bang for the buck.
Old Jun 6, 2003 | 02:58 PM
1KillerV6's Avatar
yea firebirdude I did look but those are 1 channel amps. You must have miss read my first post
a high powered amp and connecting 2 good 12's to it
meaning I want a 2 channel amp. Sorry I didn't quite have that clear.
Old Jun 6, 2003 | 03:02 PM
97FormulaWS-6's Avatar
you can run 2 subs off a MONO amp.... That's what a LOT of people do... Including myself... it's called wiring the subs in Parallel/Series....
Old Jun 6, 2003 | 04:20 PM
1KillerV6's Avatar
Oh.....explain how?
Old Jun 6, 2003 | 04:36 PM
well, what speakers are you looking at or have? the impedence of the speakers and the impedence the amp can handle is what will determine how to wire things.
2 speakers can be wired to a single channel of an amp by either ways, depending on what ohms you want the amp to see.
Wiring them in series... + of speaker 1 to + of amp, - of speaker 1 to + of speaker 2, - of speaker 2 to - of amp. The amp will see (Ohms of Speaker 1 + Ohms of speaker 2)
Basically with 2 4ohm speakers the amp will see 8 ohms as an example.
Wiring them in Parallel, you connect both speaker +'s to the + terminal of the amp, and both -'s to the - of the amp. THe amp will see (1/what the amp sees=(Ohm 1 * Ohm 2)/(Ohm 1 + Ohm2)
Basically with 2 4ohm speakes the amp will see 2 ohms as an example.
But What speakers are you going to be using? are they single Voice coil, or dual VC? that effects things as well.
Old Jun 6, 2003 | 11:37 PM
1KillerV6's Avatar
Originally posted by 97FormulaWS-6
well, what speakers are you looking at or have? the impedence of the speakers and the impedence the amp can handle is what will determine how to wire things. But What speakers are you going to be using? are they single Voice coil, or dual VC? that effects things as well.
I donno yet.....but right now i've got 2 of these 10's. I like them a lot but I think my amp suxs and is holding back their capabilities. Should I buy some 12" subs next then a good matching amp or an amp then matching subs?
Old Jun 7, 2003 | 12:15 AM
1KillerV6's Avatar
2 voice coils is better than 1 right? Also....the lower the load(ohms) on the voice coil the better right.
Does this sub seem good or could I get better? I've got some 10's sorta like that and I like it....but I also don't have a lotta power to it so I don't know how hard they hit or how crisp they sound at high volumes . Those 12's above say:
·2.5" 4-Layer ASV Voice Coil ---- What exactly does that mean?
·Dual 4 Ohm ---- Dual? meaning 2 voice coils???
·2 Ohm or 8 Ohm Operation ---- That depends on how u wire it right?
Old Jun 7, 2003 | 12:46 AM
bt96ss's Avatar
It all just depends on what amp you are looking at. personally I think the audiobahns are junk. We used to sell them in our store. We have a pile of them in a corner waiting to be shipped back. They all have bad coils or broken tensel leads. No impedance is better than another. In the past you had to get a dual voice coil speaker if you wanted to use big power. Now companies make single coil speakers that take big power. I say look for a 600.1 Jbl like someone else said. Find two 4 ohm or two dual two ohm speakers and rock. For speakers I would look at image dynamics, Jl audio, treo, mmats, cadence and cutting edge just a name a few.
Old Jun 7, 2003 | 01:17 AM
1KillerV6's Avatar
The funny thing is that I have never heard of those till now
Back to wanting a powerful amp(preferably 2 channel bcuz I can always bridge it right?) with high RMS power that I can hook up to 2 12's and having a low load.
Old Jun 7, 2003 | 01:24 AM
bt96ss's Avatar
Use a mono block for bass. You can run a million speakers off one channel as long as you wire them right. MONO BLOCK. Leave the two channel amps for the highs.
