What direction should sub face????
Old Oct 9, 2002 | 11:06 PM
supercrosser's Avatar
Question What direction should sub face????
In a 1969 camaro what would be the best way for the subs to face? should they face towards you or towards the back? or should i set them face up? and how much would sound be affected if i had them facing each other but on opposite sides of the trunk? i have two 10" Audiobahn's thanks for any help.
Old Oct 10, 2002 | 06:35 AM
ChameleonGreen's Avatar
I'm not familiar with the layout of that body, but the general rule is that you will gain more SPL (aka louder bass) by facing them backwards. I had two 12inch subs firing towards eachother on each side of a 4th gen body, and it hit pretty well, though I didn't much like the sound of the bass. I do believe a lot of the bad sound though was because the subs weren't quite properly matched to the boxes I had them in.
Old Oct 10, 2002 | 10:05 AM
Rashiki's Avatar
...face them firing back into the trunk...this will give more resonance room and give you tighter, more responive bass curve, not to mention louder bass. You will also get less distortion as well. This gives the sound wave more time/room to expand and be true to the sound of the signal!
Take care,
Tim
Old Oct 10, 2002 | 12:21 PM
Thanx for the help i will try it. i still would like to know a little more about what it would sound like if they are facing each other on opposite sides of the trunk. but thanx for the other help i hope it works.
Old Oct 10, 2002 | 04:18 PM
ibanez6rg's Avatar
Face them away from you, they'll sounds 10x better
Old Oct 11, 2002 | 03:42 PM
Jibberish18's Avatar
I agree with the above statements.
jayblev95
Sep 26, 2015 09:44 PM
alliance12364
Sep 17, 2015 08:43 AM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
