What dash kit to get???
Old Jul 6, 2003 | 01:36 AM
notstock4long's Avatar
Okay, I put my head unit in my firebird (4th gen), and the install kit completely sucked. It still moves around and the trim ring that goes around the climate controls and deck won't stay on over it. I swear I used half of my old erector set to get this thing to stay in. Is there a certain brand that actually works? This thing is seriousley a piece of junk, the deck had no where to bolt to, except the plastic thing in the back that rests in a hole. And where should I get an antennae adapter? Thanks
Old Jul 6, 2003 | 04:49 AM
LS1 RULZ's Avatar
Try the Metra 99-3009 dash kit.
Old Jul 6, 2003 | 09:53 AM
Okay, does the deck actually screw into that one? I will check into it.
Old Jul 6, 2003 | 10:54 AM
LS1 RULZ's Avatar
Screw in? No, you slide the HU's sleave into the kit and bend little tabs to hold the sleave in place. Then you slide the HU into the sleave.
Here's what my Alpine looks like in the 3009...
http://images.cardomain.com/member_i...2_102_full.jpg
Old Jul 6, 2003 | 06:51 PM
Okay, I ordered it, but I'm still not sure what you are saying. Is my head unit supposed to have a sleeve? Because someone else installed it in my other car, then I put it in this one, so maybe I forgot something??? Or does this kit come with a few different sleeves that work with different decks. Thanks for the help
Old Jul 6, 2003 | 07:31 PM
NineSevenWS6's Avatar
The GM Multi kit > 3009.
http://www.indi-x.com/gallery/album19/radio2
I like it a lot better than having the radio recessed into the kit. The texture is a lot smoother too, for a cleaner look.
The sleeve comes with the radio, not the kit. Sounds like you didnt get it out of the cold car/kit. Or you havent bent the tabs to secure it into the new kit.
Old Jul 6, 2003 | 10:25 PM
Ahhh, where is my sleeve? This is definately my problem, I swear my deck is gonna break my hand one of these times when it falls out. Maybe they didn't use it and it's still in the box. I hope I can find it. I already ordered the 3009, so I hope it works. Thanks again for the help.
Old Jul 7, 2003 | 02:00 AM
81formula'bird's Avatar
if u need a sleeve yuor local stereo shop will usually have an extra one in stock. i know they did for me before
Old Jul 7, 2003 | 10:53 AM
This is true. I probably have 30 in the counter next to me.
Old Jul 7, 2003 | 11:02 AM
97FormulaWS-6's Avatar
yea, you're going to need the sleeve... they're pretty much Brand specific too.
Also... Kit's aren't necessiary... I made my own mtg plate from a piece of 1/8" aluminum... with a jigsaw and a template I made from the kit I used to have, ruler, and sharpie.. then just mounted it with the stock screws and some washers.
Although I had to remove that stupid rear tab to get the raido to recess enough.
Old Jul 7, 2003 | 03:52 PM
Do you think you could send me one? I can paypal you for the shipping. It is a pioneer dehp-8400. So do you think Circuit City or ABC warehouse might have one laying around?
Old Jul 7, 2003 | 04:42 PM
CC should have one. Theyll probably charge ya $10-15. If you catch someone nice, they might give ya one.
Old Jul 9, 2003 | 03:20 PM
convertz's Avatar
Cool
I just put a blaupunkt radio in my 94 Camaro, with the Metra kit, should I put something behind the radio to hold it up? Right now its just being held in by the metal sleeve. Theres a stud commin out the back of the head unit, should i make a bracket to attach that to the dash?
-Ted
Old Jul 9, 2003 | 04:37 PM
LS1 RULZ's Avatar
You should if you can get to it. The added support will help prevent skips. I wasn't able to so I added padding beneath the HU to help stabilize it.
Old Jul 9, 2003 | 07:49 PM
convertz's Avatar
That makes sence. I took it for the first highway ride today and it skips like a mother over every expansion joint in the road. Gotta get back there with my erector set.
thanks
-Ted
