VATS bypass
Old Jun 20, 2004 | 04:16 AM
dabez1's Avatar
VATS bypass
I need a lil bit of help on bypassing it. I found the resistance of my key and soldered several resister adding up to the resistance of the key. I was able to find the vats connector under the steering column, orage sleeve with 2 wires. My question is where exactly do i have to solder the ends of the resistors. Could someone illustrate where to solder the resistors on the wires on a picture or explain it to me.
thanks in advance
Old Jun 20, 2004 | 07:45 AM
Brent94Z's Avatar
Super Moderator
Re: VATS bypass
thanks in advance
Cut the two wires in the orange sleeve. Take the ends that go up to the ignition and tape them up as you won't be using them. Take the ends that go off to the VATS module and strip back the insulation. Connect one end of your resistor "string" to one of the wires and the other end to the other wire. You have now just bypassed the IGNITION part of your VATS/PASS Key system.
Old Jun 20, 2004 | 12:42 PM
dabez1's Avatar
Thanks for the help, gonna go try it
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
