Upgrading the Bose System
Old May 30, 2005 | 11:34 AM
aaron1987's Avatar
My Bose system is shot through and through as far as I'm concerned, I have a blown driver's side speaker and the HU no longer plays CD's, so it's definitely time to upgrade. I haven't had any real experience with car audio up until this point so I've been reading up on it and believe I've found a system that should sound pretty good without breaking the bank.
A Pioneer DEH-P3700MP head unit
Two Alpine SPS-170A's for the driver and passenger side doors
An Alpine MRP-F240 4x40w amp (1 to each speaker, 2 to the sub)
And either an Alpine SWR-1021D or a Kicker 0210L5 in a stealth box from subthump.com
Is there anything I'm forgetting such as adapters etc? Any other thoughts, advice, or recomendations for this setup would be greatly appreciated. Thanks a bunch in advance!
Old May 30, 2005 | 09:07 PM
FLOW-MAS-TER's Avatar
Re: Upgrading the Bose System
make sure you know how to bypass the bose amp that's in the car.
if you don't do it right, your deck wont work.
Old May 30, 2005 | 09:34 PM
Rashiki's Avatar
That's what RCA pre-outs are for.
And just run new speaker wire and screw the stock puny razor thin garbage. It's easy as hell and works much better.
Old May 31, 2005 | 12:54 AM
PentaVolvo's Avatar
honestly i would reccommend a bigger amp or a seperate sub amp, 100watts rms to a sub isnt much
Old May 31, 2005 | 01:15 AM
94'_Z28's Avatar
This I will agree with. Both the Type R and L5 are pretty power hungry subs, and neither of them are really that efficient (will take more power to get loud). I would really suggest getting some components up front, and a 2 channel amp for them. Then getting a mono amp that will push at least 400 watts RMS at whatever ohm you need for your sub (dual 4 ohm sub will equal out to be 2 or 8 ohms, and dual 2 ohm sub will be 1 or 4 ohms).
CamaroHeed
Mar 18, 2020 09:50 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Rodrigues
Sep 5, 2002 05:40 PM
jwright3SS
Jul 30, 2002 03:49 PM
96CamZ
Jul 27, 2002 04:13 PM
