Upgraded wiring?
Old Apr 26, 2007 | 11:04 AM
eagleknight97's Avatar
Upgraded wiring?
Im trying to stiffen up my audio system without getting a new alternator or adding a capacitor. Ive read on here about upgrading the wiring helping with LS1 applications, I think White Rascal has talked about it, and I was just wondering if the same will work for LT1's. I saw this link over on LS1tech and wanted to see how you guys over here thought about it.
http://www.innovativewiring.com/Chev...amaroPage.htm#
I dont have a huge power problem, but the lights dim slightly when im at idle and got the music up a little.
Old Apr 26, 2007 | 01:38 PM
fredmr39's Avatar
Generally upgrading the "big 3" helps all charging systems (though I don't think all 3 need to be upgraded in ours)... Hard to predict if it will help you, because from what I've read - sometimes it does wonders while others claim only a HO alt will help..
Might as well give it a try, IMO. (IDK if prices from where you listed are the best though)
Old Apr 26, 2007 | 09:22 PM
ReNxWar's Avatar
I've been planning on doing this for alittle while now. You can make the kit yourself for ALOT cheaper than 80$, though. Go to knukonceptz.com and get the wiring yourself.
Old Apr 27, 2007 | 09:06 AM
PentaVolvo's Avatar
knukonceptz wiring can be had for much less. i highly recommend it it will help alot with dimming, every car ive done it on ive seen a big help, and i recommend doing all 3 legs. on my buddies LT1 WS6 he has a 70*4 rms 4 channel and a 1200 wrms sub amp and we did the big3 and his light dimming is almost gone and it was pretty bad
ModdedNerd
Feb 5, 2015 04:37 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
