Troubleshoot me please!
Old Apr 24, 2003 | 09:44 PM
WheelmanZ28's Avatar
Hey ppl
I was cruising around tonight for the first time in a couple weeks in the camaro, making sure everything was all good. Car ran good, stereo super. So i get to my friends house and stop. I come out couple hours later, start the car, NO BASS FROM THE SUBS
I get home, check the fuse - good. check the connections on the amp - good. connections to the sub and deck - good. Try switching fuses - nothing. I look at the amp, the red light is glowing really dull, and it pulses slightly to the beat. Usually its a bright solid red
I have a Pioneer 760W amp and 2 10" image dynamics v.3 subs. Sony deck and rockford fosgate wiring kit
PLEASE HELP!
Old Apr 24, 2003 | 11:08 PM
NineSevenWS6's Avatar
Check the ground, then make sure it has 12v+ at the battery lead and the remote wire.
Old Apr 24, 2003 | 11:16 PM
RallyRedTexan's Avatar
That and try running you car for a while without the stereo to give the battery a chance to charge. If it has been siting for awhile then you may be running too low of a voltage to power the amp, but check the other stuff first. It's best to verify it with a DMM.
Old Apr 25, 2003 | 12:48 AM
x7x7's Avatar
Sounds like a ground problem. Where did you ground to? What gauge wire did you use for power and ground? Did you scratch the paint away from the metal?
Old Apr 27, 2003 | 07:54 PM
Thumbs up
Thanx for the help guys, turned out the ground DID loosen up a little. I tightened the bold to the ground and everything is all good. thanx again
jbert55
Oct 31, 2015 03:52 PM
tommalcolm
Sep 11, 2015 03:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
GOATCRAZY
Mar 9, 2005 12:42 AM
SSkindog
Advanced Tech
Aug 19, 2003 04:26 AM
