subwoofer wiring?
subwoofer wiring?
ok, so i have a kicker kx600.1 amp that is rated at 600 watts at 2 ohms, and 300 at 4. I kinda have an idea about ohms, but not that much. I also just got a l7 solobaric, that is dual 2 ohm. It says that both voice coils need to be hooked up and it gives two examples of how to do so. Wired in parallel the sub has a 1 ohm load, and wired in series it is at 4 ohms. Since my amp puts out 600 watts at 2 ohms, which way should i wire it? I would like to be able to use the full 600 watts, but will it hurt anything to have the sub under a 1 ohm load. Like i said, I really dont know anything about ohms, and stuff, so if someone could explain it to me or help me out, i would appreciate it.
Unfortunately your amp is only stable down to 2 ohms. You make it seem like if your wording that if you wire it at 1 ohm, the sub will get 600 watts -- however that is the power at 2 ohms -- at 1 ohm the amp would try to produce more than 600 watts where it isn't stable and will more than likely fry shortly.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
themushine
Sep 3, 2002 10:01 AM
