Subwoofer Set-Up Help!
I just purchased some subwoofers for my 1994 25th anniversary trans am. I have a question about setting them up. I ran the power cable, but I need help with the audio inputs. There are two options: there is a 5-pin connecter (Left and Right (+) and (-) frequencies and ground) that is for high inputs for cars with stock stereos (mine is stock) that you have to splice with a set of speakers, or there is an RCA cable (red and white) that connects to a newer replacement head unit. However, I was wondering if I could just cut off one of the ends of the RCA cable and connect it to one of the speakers next to the back seats, since those speakers only receive bass frequencies anyway. Which is better? Help greatly appreciated, I am putting them in today hopefully.
Re: Subwoofer Set-Up Help!
Don't even think about putting RCAs in like that... you WILL destroy something.
You basically have to options, run thie Speaker-Level ins on that amp, or buy a Line-Level Converter and use that to convert the speakers to RCA levels, and then use the RCAs.
RCA's are meant to have a lower voltage (2-4 usually) applying a signal to the amp... theres a reason for the other inputs... theoreticaly it should work.. but it def doesnt...
Originally Posted by PipesTA
Get a PAC convertor.
Desolate_Flux
Nov 25, 2002 10:23 PM
93_Z28_6spd
Oct 10, 2002 09:53 PM
jim88iroc305
Aug 13, 2002 09:24 PM
