subs are cutting out..
Old Jan 3, 2007 | 05:16 PM
Chevy16's Avatar
like the title sais my subs keep cutting out every time i turn it up to the loudness i want it, the amp and subs are getting power to them but they just cut out all the time and dont work, and as far as i know it only does it when i play my cds, it does it with every one of them.... what could be causing this?
Old Jan 3, 2007 | 05:24 PM
streetracerx's Avatar
maybe a weak connection between the wire ends at the sub or amp end, maybe check for pinched wires, ive heard they can make things cut out.did it just start, or has it been going on since you hooked it up?
Old Jan 3, 2007 | 06:27 PM
CamaroSS30thAnn's Avatar
check all ur wires and all your grounds
check how many ohms ur speakers are pulling , easiest way is to do this is to c how many ohms each sub is and how u wired them
if the amp is only capable of a 2 ohm load and ur running it at say 1 ohm load ur amp may overheat going into protect causing it to turn off and on cutting ur subs out
i havent been into systems in a long time but this is what id do.
Old Jan 3, 2007 | 06:32 PM
wakebordr2006's Avatar
yup. just sounds like your amp is over heating. checking the number of ohms your subs are running and make sure your amp is well ventilated
Old Jan 3, 2007 | 07:36 PM
Chevy16's Avatar
it just started, my subs are 2 12 inch mtx 4500s, i think theyre... 4 ohm each... my amp is only a 300 watt max pioneer but it powers them just fine when it isnt cutting out and i dont have the gain turned up all the way eather
Old Jan 4, 2007 | 12:44 AM
Bayer-Z28's Avatar
I had the same thing happen to me in my last car. The amp was the wrong size. It was also a Kenwood 200w amp, rigged up to dual Kicker Comp 12's... I COOKED that amp!
Old Jan 4, 2007 | 12:55 AM
95LT1conv's Avatar
that amp is WAYYY too small. if it is 300 watt max, then the rms wattage is half that or less. the speakers you are trying to push are probably rated at the same rms as the PEAK of your amp. i would suggest a minimum 500 watt
Old Jan 4, 2007 | 01:00 AM
Bayer-Z28's Avatar
I was a MAJOR stereo newb back then. The RMS on the Kicker Comps was prolly a Min of 150, I was running the amp's MAX 200 to them at the wrong impedance.... .. ohwell, cheap, and first sub setup. Live and learn.
Old Jan 4, 2007 | 10:48 AM
id have to agree ur amp is way to small the speakers wnt more power ur amp cant put out
Old Jan 4, 2007 | 02:53 PM
Chevy16's Avatar
and i agree with all you guys lol, ill just have to snag another amp from my uncle or something
Old Jan 4, 2007 | 03:35 PM
valter's Avatar
If all connections are solid, amp is probably falling into protection mode. Then it's time to upgrade to a real Class-D amp from respected manufacturer.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
