Subs and Amps --- NEED HELP!!
Old Jul 19, 2003 | 04:59 PM
30thAnniversaryZ28's Avatar
Red face Subs and Amps --- NEED HELP!!
I am looking at getting an Infinity KAPPA 100.3SE 10" Subwoofer Single Voice Coil rated at 275 RMS/1100 Peak. Or an Alpine SWS-1041D 10" Type-S Series which is rated at 200 RMS/600 Peak and it's a Dual Voice Coil.
What is the difference in a Single Voice Coil vs. Dual Voice Coils? I am only planning on getting one sub but I don't know which would sound cleaner and fill out my low frequencies as well.
What type of amp would you use to power these subs. Is there a general rule for matching an amps power with a subs power? I am not quite sure about 4 ohm vs 2 ohm ratings!
Your 2 cents is greatly appreciated!!
Old Jul 19, 2003 | 11:06 PM
firebirdude's Avatar
There have been a lot of positive reviews about the Alpine Type-S. The advantage of a dual voice coil woofer vs. single coil is just wiring flexability. No difference in sound. Which you should get depends on what amp you plan on getting. Most likely a single 2 ohm or dual 4 ohm woofer. Unless you get a 2-channel amp and plan on bridging. How much do you want to spend on a sub amp? Do you already have an amp on your other speakers?
Old Jul 20, 2003 | 02:04 PM
I am looking at spending about a 100 bucks on a sub and am looking for a solid amp to drive it so price isn't a huge concern...under say 250.
My other speakers are not driven by any amp...just my head unit (Alpine 9805 reciever).
Old Jul 21, 2003 | 12:37 AM
RallyRedTexan's Avatar
Hmmm, let's just combine your budget and go from there. So you're looking at around $350 total. With that kinda money I'd go with either an Alpine Type-R or preferable an eDesign K-series in 4ohm or dual 2ohm. Get a USacoustics USX2150 (450W x1 WAY under rated) and you'll be pimpin' it oldskool style. That K-series works beautifully in a wooden driver's side box from www.subthump.com .
Old Jul 21, 2003 | 01:03 AM
Why 4ohm SVC or 2ohm DVC? Why run at 4 ohms? The amp you recommended is a mono amp correct? Then I'm sure it's 2 ohm stable. Or is that power rating when bridged? And 30thAnn, have you thought about a box and wiring yet? That's another expense. Go with Red's recommendations. Good stuff.
Old Jul 21, 2003 | 08:09 PM
I can get the Alpine Type-S sub for 70 bucks.
Unless I'm mistaken you can only buy eDesign subs at their website right?
I'd like to take the rest of the money and get a good amp to power it so it sounds solid. Is the USacoustics USX2150 a solid amp to run the Alpine with? Where do you buy it at?
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
Aug 3, 2015 08:42 AM
Latronaxe
Jul 17, 2015 11:55 AM
