Which setup????
Old Jan 14, 2004 | 11:10 PM
YOUNGGUN96's Avatar
Which setup????
ok guys here is what i have. 4 fosgate 10's. all 4 are 8ohm, 2 of them are 200 watt rms and the other 2 are 150 watts rms. The way i am wiring them requires me to use a 2ohm stable amp. So well my (?) is would i be better off to have one 2 channel amp that is 700 watts rms at 2ohm or 2 different amps,one being 300 rms at 2ohm and one that is 400 rms at 2ohm? This has been puzzling me because I want the absolute max power to be put to them but without over powering them. So if I went with the single amp then I would be over powering the 150 watt speakers but not getting enough to the 200 watt speakers so it seems to me like I would be better off goin with the 2 amps. Now if I do do that then how will that sound? Well basically what I am asking is which setup do you guys think would sound the best without having my speakers' life on the line!
Old Jan 16, 2004 | 05:38 AM
LS1 RULZ's Avatar
For starters you should have 4 identical subwoofers. It's not a good idea to mix and match different subwoofers together.
Old Jan 16, 2004 | 01:16 PM
93Cam's Avatar
Definately get 2 different amps that match the power rating for each set of subs. Supplying a sub with its optimal recommended power will maximize quality, life, and best of all give you the hardest hits.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
