replacing monsoon deck with aftermarket
Old Apr 16, 2003 | 10:56 PM
CLEAR's Avatar
when replacing my monsoon deck with an alpine do i need anything other than the standard wiring harness? will everything still sound the same or better? i just dont want to lose quality and still want to use all the factory speakers. also whats the extra wiring harness on the deck, is it for a changer?
Old Apr 17, 2003 | 06:04 PM
Red97LT1's Avatar
Re: replacing monsoon deck with aftermarket
I replaced the monsoon with an Alpine a year ago and i got a popping noise whenever i changed the preset radio buttons or turned the volume up or down. I was told that it was the radio,i tried another(alpine) one and the same thing happened. I then put in an Eclipse and the problem was gone. Never found out what it was. You just need the standard wiring harness for the install,and don't forget the antenna adapter. I used METRA for both. I used an antenna adapter by Scosche and it wouldn't work. As for sound it sounds the same to me. And yes that extra wiring is for the cd changer.
Old Apr 20, 2003 | 02:12 PM
slayer6x6's Avatar
you will also need a mounting kit and an antenna adapter
screaminss
Sep 4, 2002 12:48 PM
SpidermanForever
Aug 30, 2002 02:13 AM
Red97LT1
Aug 4, 2002 08:01 PM
Geeterman
Aug 4, 2002 04:03 AM
