Remote start then stalls
Old May 16, 2007 | 12:09 PM
  #16
SweetZRag's Avatar
Last night I hooked up the second START wire from my alarm to the Yellow wire in the ignition harness. I disabled my VATS bypass module and left the key in the ignition. It started. So it looks like my original problem was not having the alarm connected to the Yellow wire. I am still not sure why it is needed because it appears to be the airbag circuit and and some other unneeded circuits.
Now I have isolated a problem with the VATS bypass. I need to double check my connections because I know the resistor is correct. I need to know if the VATS bypass module needs to be engaged only during START or during RUN also? I think I ca prove this by pulling they key out after the car starts and see if it keeps running.
Anybody know for sure if the VATS bypass only needs to be engaged during crank? My alarm has a separate negative output during crank that I could use if it will work.
Old May 16, 2007 | 05:46 PM
  #17
bt96ss's Avatar
The alarm should have a wire ,ground out when run, specifically for this purpose.
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jan 23, 2015 01:13 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Rod Bender
Jan 3, 2015 03:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
