Radio Installation troubles... HELP!!!
Old Aug 17, 2004 | 08:09 PM
Heatmaker's Avatar
Advanced Member
Unhappy Radio Installation troubles... HELP!!!
My Factory wiring harness was cut and I have to start from Sctrach...
I have a
Dimmer Wire
Illumination Wire
Memory Wire
Ignition/acc wire
What should I connect the wires to in the fuse panel on the side of the dash? I'm clueless...???
Old Aug 17, 2004 | 09:10 PM
moparman's Avatar
Re: Radio Installation troubles... HELP!!!
I think you can find the color code here: www.installdr.com It is possible to buy a new under dash harness. I'm sure Autozone can get one.
Old Aug 17, 2004 | 11:46 PM
Heatmaker's Avatar
Advanced Member
Hi,
I'm wiring in a stock replacement wiring harness... but I want to run fresh new wires from the fuse panel.... To keep things simple...
Old Aug 18, 2004 | 01:02 AM
Blue89Bird's Avatar
Dimmer Wire - splice into the dimmer switch
Illumination Wire - splice into the headlight switch
Memory Wire - any constand 12v source
Ignition/acc wire - any switched 12v source (whatever is powered only with the key in the on position)
sorry I don't know which colors are which, Im sure shoebox has a diagram on his site somewhere though, get a volt meter, and start digging, shouldnt be too difficult though.
Why not just splice int othe existing cut wires though, would prob be easier.
Old Aug 18, 2004 | 08:55 AM
Heatmaker's Avatar
Advanced Member
Thanks Blue
I would do the other way but no one can find all the wires they were cut that bad... no matter what radio shoppe I went to they were going to rewire the entire car.
warmeck
Mar 22, 2015 10:28 AM
dark-evader
Mar 11, 2015 07:47 AM
Airplanedoc
Feb 1, 2015 07:14 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
