quick question about ohms and wiring
Old Sep 5, 2006 | 04:02 AM
Meatyshells's Avatar
i have an older jl 10w3 whitch is dual 6ohm and im getting this amp
http://cgi.ebay.com/ebaymotors/NEW-K...QQcmdZViewItem
if i wire the sub in parallel i should have a 3ohm load, i have never seen or herd of a 3 ohm load. is it safe to do it on that amp sence its only 2ohm stable?
and if the amp puts out 850w rms (at 4 ohms) and 500w rms (at2ohms) would it be safe to say it puts out 675w rms at 3 ohms?
Old Sep 5, 2006 | 06:54 AM
LS1 RULZ's Avatar
Re: quick question about ohms and wiring
Running a 3 ohm subwoofer load with an amp that is stable down to 2 ohms is perfectly OK. You have the numbers for the amp wrong though. As the impedance (ohms) goes down the more power the amp will produce. To a point. According to Crutchfield's web site the amp produces 500W @ 4 ohms and 850W @ 2 ohms. So your figure of 675W @ 3 ohms is correct.
JL's subs with dual 6 ohm voice coils were originally meant to be used in sets of 3. That way it allows you to wire the voice coils in series/parallel to get a more typical load of 4 ohms. With each sub's voice coils wired in series each sub becomes 12 ohms. Three 12 ohm subs in parallel gives you a 4 ohm final load.
Old Sep 5, 2006 | 01:50 PM
ok thanks, and yeah it was late and i ment the ohms the other way around lol
nophix
Nov 30, 2014 10:26 PM
lbrowne
Nov 13, 2011 04:25 PM
Omega9
Aug 17, 2002 04:23 PM
Omega9
Aug 2, 2002 12:33 AM
