Questions about installing radio
Old Jun 25, 2004 | 03:12 PM
Heatmaker's Avatar
Advanced Member
My Radio was stolen out my ride... and the stok wiring harness is cut... so I have to re wire everything.... now thankfully this incident happend before I ever owned my car.. so I don't really care... anyhow I got my new wiring harness and all the other cool gadgets and I'm ready to wire up everything.. now I was just ondering for the Dimmer ... should I install it directly to the factory dimmer? switch? .... and what is the radio ACCY for? (located in ignition box)? .. .and hte memory wire that just goes to a constant 12v source right?
Old Jun 25, 2004 | 09:33 PM
Heatmaker's Avatar
Advanced Member
Old Jun 26, 2004 | 04:23 AM
LS1 RULZ's Avatar
If your HU has the ability to dim it's lights it should be connected to the dimmer wire in the factory wiring harness.
Radio Accy. is the switched power connection for the HU. It only has 12V when the key is turned on.
Memory goes to a wire that has a constant 12V to retain the radio station presets when the key is turned off.
Old Jun 26, 2004 | 08:27 AM
moparman's Avatar
You might find some wiring and color codes here: www.installdr.com
Old Jun 26, 2004 | 09:55 AM
Heatmaker's Avatar
Advanced Member
Man this you guys are friggen awsome....
Ok if the Radio ACCY is the power 12V when the key is on .... then what is the other Radio fuse for? Also located in the Fuse Box.... And memorey wire.... for a constant 12V what should I connect it too?
Damn I can't believe all thh crap I've wired up and installed on my ride...but I'm stumbling over a simple radio...
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
Jul 4, 2005 05:00 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
