'Protect' light comes on, why? New amp....
Old Mar 17, 2007 | 02:07 PM
TechCam97's Avatar
Ok, my original amp took a dump a while back so I went to Wal-Mart and purchased a cheap amp to replace it. It's only powering one 10" MTX Thunderform 4000 in a Stealthbox style box, so I figured I didn't need anything too spectacular. Everything worked fine until one day about a month later the sub stopped playing. I figured I blew the sub, which was fine since I've had it since the Summer of 2001. I pulled it out and put in a spare (a second MTX Thunderform 4000) and there was no sound. I checked all my wires and connections, all ok. I noticed the protect light was lit on my new amp, so I checked it out. The amp settings are for lows, the bass boost is not turned on, and the gain was about half way up. I turned the gain all the way down and everything worked fine, turned up the gain a bit and it went into 'protect' mode. I was in a bad mood so I yanked it out and borrowed my friends spare amp (similar amp in specs to the one I had in there) and it does the same thing. Why is it doing this? All the connections are solid, what's the deal?
Old Mar 17, 2007 | 02:42 PM
fredmr39's Avatar
OK.....I stopped reading after that.
Specs on the amp would help...and the sub (SVC ??ohm, etc).
Old Mar 17, 2007 | 03:28 PM
ReNxWar's Avatar
Check the ground.. I had the same problem on an old one I had.
Old Mar 17, 2007 | 04:37 PM
TechCam97's Avatar
4ohm for each. (4 ohm is what the amp runs at, 4 ohm is what the sub operates at.) Trust me, it's not too much sub for the amp and vice versa. It's small, cheap, and just something to add a little bass to the sound. I'm not into the massive systems like I used to be, that's why I'm not investing a lot of money in this system. I don't want it to shake the car, just add a little thump to the bottom end.
Old Mar 17, 2007 | 04:40 PM
TechCam97's Avatar
See, I tried that as well. I've always had luck grounding it where the rear hatch latches closed. There's a factory ground there and I just bolt it to that. I swapped it around so that it's grounded to where the power antenna is grounded and it still does it. Not really sure why....
Old Mar 18, 2007 | 12:00 PM
Garcia95's Avatar
same problem
hey man i had the same problem with my system and i still cant figure it out.
i have a 15 inch crossfire sub its an 800watts and has a fit plug that can be connected at either 2 or 4 ohms. the sub was off the car for about a month because it takes up too much space in the little trunk. then i got it back in the car and it worked fine for about a week then it burned a fuse on the amp.
so then i replaced the fuse and it worked for a few minutes. i then decided to try a spare amp that i had in case of any emergency. by the way the first amp was an american pro 600watts at 4 ohms the speaker was at 2 ohms. the other amp is a concept 100watt at 4 ohms the speaker was at 2 ohms.
but as soon as i connected the speaker the amp would go to protect mode so then i took the speaker out and turned the plug to 8 ohms and it worked fine. but at 2 ohms it was loud and at 8 ohms it sounds nice but its not as it used to be.
Old Mar 18, 2007 | 01:06 PM
RKPsk8er's Avatar
I would rewire the subs at a higher resitance and see if that fixes the problem
Old Mar 19, 2007 | 01:46 PM
valter's Avatar
If gains were set correctly, voice coil on a sub is not damaged (with result of dramatic impedance drop) the reason can be very poor quality amp.
Old Mar 19, 2007 | 06:45 PM
nick3's Avatar
try to disconnect the speakers from the amp, then turn the amp on and see if the protection light comes on.
May 1, 2015 01:14 PM
Apr 3, 2015 10:54 AM
Mar 13, 2015 07:15 AM
squarehead
Nov 21, 2014 08:02 PM
