Probably the wrong forum, but I need electrical help!
I figure you guys are the best to ask with electronics questions, so here it goes. My tach is going crazy! Sometimes it's fine, but most of the time the needle jumps around and just spazzes out in general. Sometimes it reads zero while I'm driving. Do f-bodies have a tach sending unit, or is it all controlled by the computer? Could it be some kind of interference causing the wire to pick up a signal from something else? Thanks in advance for helping my sanity!
-John
-John
Well, I've checked the connections where the gauge cluster plugs in, so I guess maybe the tach is taking a crap on me then. It's really annoying driving around with the tach needle having a seizure. Grrrrrr
is this an aftermarket tach or the stock one...
im guessing stock....my buddy had that happen to him on his import.... he had to spend a grand to fix it...so i dont know if its the same thing.....its prob a sending unit
Actually, I have had both the factory tach, and an aftermakerket 5" tach do the same exact thing. The aftermarket tach was tapped into the the tach wire from the Body Control module behind the pass. side kick panel. I guess this means it's upstream in the wiring somewhere. Any other guesses? Can anyone verify if we have a sending unit or not?
-John
-John
squirrels
Jul 13, 2002 01:58 AM
