power question
Old Jul 21, 2005 | 12:57 PM
kandied91z's Avatar
power question
what guage wire is necessary for 2,000 rms? how many batteries as well?
Old Jul 21, 2005 | 04:10 PM
94'_Z28's Avatar
Re: power question
2000WRMS, 1 amp, muti amps??? More info is needed.
Old Jul 22, 2005 | 10:19 AM
kandied91z's Avatar
Re: power question
why would it matter if it was one or ten amps?
Old Jul 22, 2005 | 03:23 PM
94'_Z28's Avatar
Re: power question
The more watts the amp puts out the more current it will draw. The more current it draws the bigger wire it needs. No use in buying 4 gauge if it's only a 200WRMS amp.
Also if you are actually going to have 2000WRMS, you should look into getting a HO alt. Just adding a battery dose no good, if you stock alt can't already keep the one you got charged, how can it charge two.
Old Jul 22, 2005 | 03:36 PM
chris96camaro's Avatar
Re: power question
Would also be helpful if you told if you planned to run distribution blocks, or if you are going to link the amps...
Old Jul 23, 2005 | 11:50 AM
kandied91z's Avatar
Re: power question
i'm talking about main power wire for the car in general. not a large guage step down. just curious what others would run.
Old Jul 23, 2005 | 07:36 PM
cool_guy_j's Avatar
Re: power question
4ga, a h.o. alt, a cap and you'll be fine
Old Jul 23, 2005 | 10:07 PM
Re: power question
CAps are useless, upgrade your wires for better results...
Old Jul 23, 2005 | 10:12 PM
94'_Z28's Avatar
Re: power question
Caps are not totaly uselss, just most people don't use them for what they are meant to be used for. It's fine to use them on a already upgraded electrical system (HO alt, upgraded wire, battery).
As far as the wire for your alt and stuff... I used 4 gauge for my 200 amp alt. The size wire will depend on the current going through it, and the length of the wire. Mine from the alt to the battery is only like a foot long, so 4 gauge will work just fine for me.
Old Jul 24, 2005 | 09:55 AM
Re: power question
Yea they are not totally useless but he doesnt have an upgraded elecrical system, thats why i suggested that he upgrade the wire he is runing to allow more current to flow. A cap with his current system in my opinion would prove to be useless, unless he upgraded some things...
Old Jul 25, 2005 | 03:25 AM
kandied91z's Avatar
Re: power question
well i currently have 4 gauge, 180 alternator and two standard optima yellow tops. just curious what others are running, i'll figure it out either way but it's always nice to get an idea.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
capebuf
Jan 13, 2015 07:22 PM
Injuneer
Dec 15, 2014 09:36 AM
XtremeLt1
Sep 13, 2002 08:50 PM
