A pillar
I don't know about hardtops but in a t-top car you have to take the tops out and remove a couple of screws to get them off. Also be very carefull when putting the dash back on. I had a friend replace his dash only to have to do it twice because he applied to much pressure. They are very easy to crack.
Been a while since I had mine off, but here's what I seem to recall. If yours is a 'vert or a hardtop I'm not sure, but this is how it is for a T-top car. If I'm off on any of this I'm sure somebody can correct me
1. Remove the T-tops
2. Remove the little plastic trim piece at the top corner of the widshield/T-top meeting line, there's two little screws that hold them on. Remove both of them, L+R.
3. Remove A-pillar trim by pulling gently on the panel, they are held in place by two spring clips, one near the top, one near the bottom.
4. The dash is attached by spring clips, and I seem to recall some velcro also. Start near a front corner and gently lift up with a WIDE pry tool. Don't use anything too narrow (like a screwdriver), it's very easy to crack the panel....trust me on that one!
Aug 5, 2015 08:35 AM
2QUIK6
Jul 2, 2015 07:02 AM
May 1, 2015 01:14 PM
