Ny XM Shuts off when I press the brake....
Old Sep 28, 2004 | 07:50 PM
Laymaster's Avatar
only sometimes though. Mods are in sig. XM will completely cut out when I press the brake sometimes, even if the charge is at 13.5-14 volts. What gives? I know my battery isn't the greatest right now but it's enough to start the car and all that jazz. If I run the car in accessory mode, the XM radio will stay on for about 5 mins before it turns itself off for lack of juice.
The radio will cut out with the headlights on or off.
Old Sep 28, 2004 | 11:56 PM
Javelin3o4's Avatar
Re: Ny XM Shuts off when I press the brake....
how's it wired? to a cig lighter? or hardwired to the vehicle wiring?
Old Sep 29, 2004 | 01:18 AM
Laymaster's Avatar
the power wire is through the fm-modulator. It is piggy-backed to the radio power line.
Old Oct 2, 2004 | 09:20 AM
Laymaster's Avatar
bump
Old Oct 4, 2004 | 10:50 PM
Laymaster's Avatar
ttt
Old Oct 12, 2004 | 10:13 AM
audioman's Avatar
what brand is it? delphi?
most newer car audio products have a safety cut off if there is a voltage drop. It could be dipping enough to trigger it. If the XM only runs for 5 minutes in acc, you definitely need a higher CCA battery. Most average systems (500-1000watts) require at least an 800 CCA battery. Since your stock alternator only puts out an extra 10-15 amps for accessories, there has to be a buffer (battery, capacitor) for extensive add ons.
Aaront810
Aug 29, 2020 09:34 PM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
KYWes
Sep 26, 2015 08:49 AM
Sep 18, 2015 03:46 PM
