Newb needs help constructing his sub box.
Old Feb 24, 2005 | 01:38 PM
AronZ28's Avatar
I need some advice on constructing a sub box that will hold my 12" Eclipse woofer in the driver's side rear trunk cavity.
How did you secure the box to where it won't budge when I drive like crazy?
If anybody would send me some dimensions or a design for a sub box that you have built, that would be great too. I'll fudge the dimensions a little to get the exact volume correct for my application.
How did you seal your box to where it is air tight? I figure I'll use some silicone cauk on the joints.
Old Feb 24, 2005 | 05:26 PM
97FormulaWS-6's Avatar
Re: Newb needs help constructing his sub box.
For cubbyhole boxes, I typically use a combo of 3/4" MDF (For the baffle to mount the speaker) and fiberglass.
Most MDF only boxes I seal with Liquid Nails, works awesome for subwoofer enclosures and seals them right up.
Don't use Silicone to seal speakers to enclosures, it can react with the speaker surround/seals and cause problems. Most subs have their own felt seals that work well, and if you want extra sealent, then use some Plumbers Putty.
AviatorDave
Dec 19, 2016 06:35 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Aug 5, 2015 08:35 AM
May 8, 2015 11:30 AM
