Need bass blockers for componant speakers?
Old Feb 1, 2004 | 11:47 PM
convertz's Avatar
Question Need bass blockers for componant speakers?
I have been running a blaupunkt head unit, with pioneer front speakers, and the stock fronts in the rear.
I have recently bought a set of MTX crossovers and tweeters and infinity kappa mids. I plan on putting them up front and moving the pioneers to the rear.
I will be running these speakers off of the headunit, and have a sub to bring up the low end.
My question is do I need to put bass blockers before the crossovers of the comopnants so I dont blow them out? Ore will the crossovers do that for me?
I plan on running bass blockers on the rears.
thanks
-Ted
Old Feb 2, 2004 | 12:12 AM
GSteg's Avatar
IMO, bass blockers aren't really that great. They are just simple 6db octave capacitor that goes inline with the speaker wires. You'll attenuate the frequencies only a tad bit.
Example:
Say at 100hz (midbass), your speakers are putting out about 110 decibel. At 50hz (bass), its putting out 104 decibel. Therefore it is equivalent to having four times less power at 50hz. So it's comparable to having 100w at 100hz, but only 25w at 50hz.
It'll help, but not much for what you pay. If you can, I would highly recommend you make your own 12db octave passive crossover. Using the same method (inline with speakers), you can get a 6db octave capacitor and a 6db octave inductor to get a 12db octave slope. So intead of 104db at 50hz, it's approximately 98db.
But if you just need to get rid of some bass, then the bass blocker should work alright.
Old Feb 2, 2004 | 10:41 AM
convertz's Avatar
So the crossover from the components wont block any bass correct?
Old Feb 2, 2004 | 10:47 AM
GSteg's Avatar
It will block bass, but very little. Only 6db octave worth. If you just want a bit less bass from your speakers right now, then the bass blocker will do. If you want to greatly reduce the bass, as much as say an amp's xover will, then you'll want to make your own or find someone that will make one for you.
Old Feb 2, 2004 | 10:51 AM
LS1 RULZ's Avatar
No, the crossovers will not high-pass the signals to the component speakers. You need an active/electronic crossover and separate amps for that. Or you can try building a 12dB/ocatve high-pass filter yourself.
Old Feb 2, 2004 | 12:54 PM
convertz's Avatar
Thats what I thought, what would it take to build a 12db X-over?
An inductor and a capacitor was mentioned above, but wouldnt the inductor block the high frequencies I want?
Old Feb 2, 2004 | 12:59 PM
GSteg's Avatar
It depends on how you wire the two together.
Here you go.
http://www.partsexpress.com/resources/xover.html
Old Feb 2, 2004 | 01:20 PM
convertz's Avatar
Thanks, that really helps me out quite a bit.
thanks
-Ted
Old Feb 2, 2004 | 02:02 PM
LS1 RULZ's Avatar
Parts Express has got pre-built X-overs you could use. Here's their 80Hz 12dB/octave high pass filter. You'll need a pair of them.
Old Feb 2, 2004 | 02:19 PM
ImportKILLER's Avatar
What good are the crossovers that come with components then?
Old Feb 2, 2004 | 02:24 PM
GSteg's Avatar
The ones that comes with the components Highpass the tweeter, and Lowpass the midrange, but it doesn't highpass.
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
Bxlt1
Sep 10, 2015 08:16 AM
damnyankee36
Sep 9, 2015 07:06 PM
Latronaxe
Jul 17, 2015 11:55 AM
