My stock alarm is mezzed up please help !
Old Jan 31, 2004 | 10:48 PM
SpeedzAdisease's Avatar
Angry My stock alarm is mezzed up please help !
Stating today when I turn the key in a forward position the alarm goes off and it won't let the car start. I have tried everything that I know to do. I srewed with playing with the key in the dorr and the ignition and the alarm keeps going off when I try to start it. I have no keyless entry pad the car was bought without one. Can I bypass the darn thing I have no freakin ride I'm stuck. The alarm is stock. PLEASE HELP I'M FREAKIN OUT GUYS ! thanx
Old Feb 1, 2004 | 02:02 AM
Javelin3o4's Avatar
you would have to pull the lower dash panel off, locate the alarm brain and check to see if the starter kill is built into the brain or if it has a seperate starter kill relay, if it has a relay just remove the relay and reconnect the wire that was cut in half to connect the relay, if the relay is built into the alarm you may be able to get away with disconnecting power to the brain.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Rich_z28
Sep 13, 2002 03:35 PM
BAD 97 WS-6
Sep 11, 2002 01:45 AM
dreamer1q
Jul 24, 2002 04:39 PM
