In the middle of building a fiberglass box...have a question
Old May 23, 2003 | 09:27 AM
Marky82's Avatar
I'm in the middle of building a fiberglass box for my Camaro Convertible. I have 3 layers of fiberglass in it so far, 1 layer of mat and 2 layers of cloth. How many more layers should I add and should I add wooden braces? Anyone have any suggestions about what I can do to the box...its to much time and money to "learn by experience" so please any input is greatly appreciated!
Old May 23, 2003 | 02:16 PM
95 3.8's Avatar
a little something
Old May 23, 2003 | 05:45 PM
RallyRedTexan's Avatar
Try and get it to about 3/8" thick. The number of layers all depends on what oz. of stuff you are using. Let me know if you have any other questions.
Old May 24, 2003 | 01:16 AM
Marky82's Avatar
I'm not sure what oz the stuff i'm using is.... I bought it at home depot. So far I have 2 layers of Mat and 3 layers of cloth. I was going to add 2 wooden braces tommorow then start to fiberglass the top on. I've never done anything with fiberglass before....I hope this box sounds good.
Old May 24, 2003 | 01:54 PM
Just use the thickness I gave you as a guide. Since you're also using a woven cloth you can run it a little thinner. Most of the stuff at Hoem Depot is around 1 1/2 oz. the last time I looked. If you ever need anymore check out www.USComposites.com they have great prices. I use their cheapest Polyester Resin and it's much better than anything I've tried from Home Depot. If the box is really larger a few wooden braces if probably a good idea. Dowel rods work well. As does just good ole 1x2's.
transam_388
Mar 15, 2015 11:53 AM
Moshbmx1
Jan 20, 2015 03:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
steve10358
Aug 1, 2002 01:05 PM
