left brake light wont dim, help!
Old Aug 22, 2006 | 12:42 AM
96 TA's Avatar
With the lights off both rear brake lights work correctly, with the lights turned on the left rear brake light shines bright as if I were pressing the brakes while the right one remains dim as it should untill I press the brakes. What would make the left brake light stay bright and not dim. The car is a 1997 camaro, thanks!
Old Aug 26, 2006 | 03:06 PM
1st TA's Avatar
Lightbulb Re: left brake light wont dim, help!
If you have not already tried it, replace the bulb. It may be that the filliment inside the bulb has broke and became attached to the tail light part of the bulb.
Hope this helps.
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
