Just Installed Amp and Satellite Radio, all seems to work, how do I adjust Amp?
Just installed myself, feel so proud, a Crunch BlackMaxx 4 channel amp, and Sirius Sattelite radio. Running Infiniti Kappas up front, and Infinitti Refrence in the rear. Both are 2 way's.
The fronts have a crossover built into them, the rear's dont.
I connected everything up, how do I start adjusting, how do I know where the settings should be?
Also, what should the passes be on the amp for front and rear?
Also, how do I know that the +/- are set correctly on the amp and on the speakers.
when tuning the amp, it all depends on what sounds good to you and getting the crossover points right where the sub will bled with the mids. You should have your mids and highs high passed and low pass the sub. the pos and neg should be marked on the amp and just match it on the sub
ok, I'm assuming that you used the factory wiring for the speakers. check it out at www.installdr.com and see the speaker wire color codes. A quick way to look is if one woofer is going in and the other is going out, then you have one of them crossed
Anderson
07-28-2002 10:57 AM
