JL's breaking glass
Old May 23, 2007 | 04:55 PM
Campbell45's Avatar
JL's breaking glass
okay I was asking a guy about the JL 12W7 becuase I was going to get two of them in my last camaro but now I have ttops so it wont work but anyway he said that if i put two 12W7's it could break my glass. I dont really believe but i will believe this. At a different audio shop. a kid put two 13W7's in a trans am ttop and supposedly he blew the seals off the ttops. I dont think i'd want to test this out but how much do you guys think it would take to blow those things off? by the way anyone here have JL's? im getting the stealthbox on driver and passenger side (custom) with w3v3's.
Old May 23, 2007 | 11:24 PM
bmnicolosi's Avatar
In my avalanche i had 3 jl w3 15's. they will hit hard but as far breaking glass.... that takes a whole lot. As far as blowing the ttop seals, if the car was completely closed off, air pressure will release through the weakest spot it can find. Thats why alot of cars with sunroofs and a lot of bass have the same problem. But, you going with w3 in such a small sealed box, you're not gonna break anything. It will sound great, but no be on the ignorance level.
Old May 24, 2007 | 12:45 AM
PentaVolvo's Avatar
2 15s firing straight at the glass on 1200+ watts rms and neve a problem, ur not breaking class
Old May 24, 2007 | 01:10 AM
Diesel151Z's Avatar
A 10W3 in a stealth box is about the perfect setup for a camaro unless you are big into competitions or need bass that you can hear a mile away. Putting 2 12W7's in an fbody would be pretty much be suicide for your ears. Especially if powered right. I don't know if they would bust your rear window, but I don't think it would be too far off. Those things are 750-1000 Watts a piece, and punch like Tyson. At most I would go with a W6, but that wont fit in the drivers side stealth.
Old May 24, 2007 | 10:07 AM
qboneus's Avatar
I have had problems blowing seals in the past, in different vehicles but I was like pentavolvo running a pair of sealed box 15's with 1500 watts outa some hcca's.
It will take out windowseals if you pound too hard without opening your windows\sunroof ect. next highest casualty item would have been alternators\batteries.
Never broke a window with SPL, more likely to do it with UHF than low freq anyways.
Tal
Old May 24, 2007 | 01:44 PM
Ray@NitroDaves's Avatar
the w7's and the w3's are 2 total different animals.
Friend of mine had an Escalde w/2 13w7's...flexed the roof 3-4 inches and blew the seal on the rear hatch.
Old May 24, 2007 | 03:43 PM
shock6906's Avatar
High frequencies break glass, not low ones.
Old May 24, 2007 | 05:24 PM
DZNUTTS's Avatar
your gonna need alooooooooooooot of power to do that,
and more than a pair of 12's.
Old May 25, 2007 | 03:43 AM
Rashiki's Avatar
Put down 147db, and all glass is intact.
Old May 25, 2007 | 12:38 PM
valter's Avatar
Trust me, you want a 10w6v2 in you stealthbox!
Old May 25, 2007 | 05:32 PM
bt96ss's Avatar
I've had solo X ported with Kicker 2500. The hatch went crazy and people woudn't sit in the car and still no breakage.
Old May 25, 2007 | 10:13 PM
pcgamer4life's Avatar
Theoretically, any frequency can potentially break glass... just depends on the resonance of the material. But that point aside, I believe we're dealing with a pressure (dB) issue here, not frequencies.
As for the subject at hand, you'll be fine. I'm not a big fan of huge systems or anything, but your ears are going to bleed before you ever shatter glass with a small setup like that. And as for blowing ttop seals... it's possible, but again unlikely. I guess if you had, for some reason, completely sealed the vehicle off from any pressure escaping, then it might be enough to break the seals... but I highly doubt it.
Old May 25, 2007 | 10:19 PM
JakeRobb's Avatar
Super Moderator
If any pair of 12's was going to break your seals, it'd be a pair of 12w7s. That said, there is NO WAY you need that much bass in a car as small as an F-body. A single 10" is best for sound quality IMO. If you like your bass extra thumpy, go for a 12". If you like more than that, well, then I guess you won't listen to my advice.
Old May 26, 2007 | 10:32 AM
shock6906's Avatar
Just play with the windows down or cracked and it won't matter what you do. The pressure will have a way to relieve itself.
Old Jun 1, 2007 | 03:48 PM
Campbell45's Avatar
i'm not saying W3's will break glass. heck no haha thats a laugh but 13W7's could get up there. prolly wouldn't break glass but it'd be doing something.
