inverted sub question
Old Aug 5, 2002 | 09:15 PM
PaulN64's Avatar
Question inverted sub question
I was wondering if you can subtract the sub displacement from the total air space if I were to invert the sub.
1997 Camaro Z-28 SS #0728
Flowmaster, Hooker Header tips, BMR strut tower brace, lower control arm and relocation bracket, Optima Yellow Top battery, Granatelli lowering springs, KYB AGX shocks, Lakewood panhard rod, Bear bump steer, 17 x 9.5 Z06 rims
Audio/Video:
Head Unit ----- Pioneer AVX-P7000CD
Master Unit --- Pioneer AVM-P9000R
DVD Player ---- Pioneer XDV-P9
Front --- Focal Polykevlar 165K2 w/ TN-51 tweeters
Rear ---- Focal Polykevlar 165K2
Sub ----- Lightning Audio 10.2.4
Amp ----- Phoenix Gold XS6600
My SS homepage
CAR AUDIO PLANET
Georgia F-Body Association
Old Aug 5, 2002 | 11:21 PM
'StangSlayer's Avatar
Post
Since the volume of the sub isnt in the box you dont count the displacement of the sub, you do need to compensate for the volume of the cone that now becomes part of the airspoace in your box tho.
'94 Black Pontiac Firebird
Suncoast Creations Functional WS6 Hood
Kenwood eXcelon KDC-x717 Head unit
1-JL Class D 500x1 amp
2-JL 10w6 Subs
Switched to a stealth setup for the subs
Coming soon.....
LT-1 & T56(next summer)
JL 500/5 5 channel amp
JL XR650-CS 2way Component System(rear)
JL XR653-CS 3-way Component System(front)
-16 and have paid for every penny of it-
Homepage: www.pennybenjaman.itgo.com
Old Aug 6, 2002 | 08:33 AM
Lynxis's Avatar
Post
ive always been a little confused here.
how do you run a system with inverted subs... also, do you hook the wiring up backwards so to compenstate for phase shifting with the other speakers in the car.... i dont know why you would but... bleh, who knows
and if you dont have to have as big of a box when you have inverted subs, then why doenst everyone do this? especially in an fbody.... of course though, you have massive subs protruding out now but....
hmm, i guess something new to experiment with...
1994 Camaro Z28 Patriot Red
Mods: MSD Wires, K&N Filter, LOUDMOUTH, AVS TailCovers, CAMARO insert
Stereo:
HU: Clarion DRX7675z
Signal: Audio Control 2XS
Full Range: Infinity Kappa Components, Audio Art Amps
Subs: 2 Rockford Fosgate Power DVC 12's, U.S. Amps US 400 (old school rev. 4)
Power Wires: Scosche
Signal Wires: KnuKonceptz
E.T: 14.09 @ 94.73
Let off @ 1100'
Old Aug 6, 2002 | 08:54 AM
97FormulaWS-6's Avatar
Post
I've seen it done in a few special applications, but normally you want the cone facing out.
This due to most of the sound comes from the face of the cone, and if you have the drive assembly in-front of the cone (as it is when mounted inverted) you block some of the sound, as well as making the surface area smaller due to the VC mounting onto the cone.
Mike
1997 Formula WS-6, 1 of 473
Mods: P&P MAF, Pro-5.0, SLP LT4 Clutch, 200 Amp Alt, TB Bypass, !AIR, !CAGS, 160 therm, CSI WP, PS Cooler, GMS STB, Cutout, TCI LineLock, ES Swaybar/Trans/TA Bushings, 5%R/20%S Tint, Painted Calipers, Custom Clear Tail Lights/Corners
http://camaroz28.cardomain.com/id/97formulaws6
Old Aug 6, 2002 | 09:22 AM
LS1 RULZ's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by 97FormulaWS-6:
Mike
</font>
This is exactly why I don't understand why people do this. Why would anyone want to sacrafice cone area just to show off a basket and a magnet? Makes absolutely no sense to me whatsoever.
Lynxis,
Yes you would reverse the polarity of the sub's wires when mounted in this fassion. At least for starters. It may sound fine wired normally. And that's only if you have an exact 180 degree phase problem. If you don't then reversing the wires won't matter.
[This message has been edited by LS1 RULZ (edited August 06, 2002).]
Old Aug 6, 2002 | 09:35 AM
PaulN64's Avatar
Post
I'm trying to see what my options are. I'm thinking of a vented box instead of sealed, and I'm trying to see if I can get away with a smaller box with an inverted sub.
Old Aug 6, 2002 | 06:56 PM
rthompson's Avatar
Post
I see there is a lot of misconceptions about inverse mounting....
Most of the sound DOES NOT come from the front of the cone.
First of all there is absolutly NO decrease in SPL, or degredation in SQ.
As we all know SPL is produced from the swept volume of the woofer compressing the air in the cabin of the car. the reason that you will not have any decrease in SPL from loss of cone area is because you still have the EXACT same swept displacement no matter which way the sub is mounted. The cone still moves the same amount and due to the porous spider and often a vented pole piece, you lose NOTHING in terms of swept volume.... Displacement is the name of the game boys.
If you are talking high frequency like a tweeter, the motor structure would block some of the direct sound, but since Bass in nondirectional it doesn't matter.... simple experiment, try to block the sound from your sub with your hand... doesn't work does it.
Yes when you inverse mount your sub, you have to reverse the polarity, and you do gain a marginal amount of space, depending on the concavity of the cone... it is probably small enough that it won't matter, but the displacement of the motor structure plus the extra (cone concavity area and cutout area) might do something... my sub is .17 cubes sub displacement, add that to the (pi*R^2*.75=.05) cutout of a 12... that is .22 cubes extra if you inverse mount my sub....
Soundillusions.net
The ultimate in caraudio.
Sony, Arc Audio, Infinity, Adire Audio, A/D/S
Old Aug 6, 2002 | 07:54 PM
PaulN64's Avatar
Question
the sub I'm looking at requires 2.5 cu ft for a ported box and the sub displaces .27 cu ft. What's the smallest air space would I require?
Old Aug 7, 2002 | 06:17 PM
rthompson's Avatar
Post
If it requires 2.5 cubes and the sub displaces .27, then if you use a standard mount, you will have to make the box 2.77 cubes. If you inverse mount then just 2.5, and if it has a nice basket then you can show it off.....
Soundillusions.net
CARiD
Jan 27, 2015 06:27 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
nautilus
Aug 22, 2002 11:49 PM
JoeD316
Aug 16, 2002 09:12 AM
