installed new Hu and sound is screeching
Old Mar 29, 2006 | 06:35 PM
3800rs's Avatar
i just installed the clarion dxz845mc headunit in my car and now when i turn up the music i get like a screech sound. i think something is screwed up it really sounds like ****. can the monsoon amp be doing something wrong with this or what ? thanx
Old Mar 29, 2006 | 07:58 PM
VTsullyman's Avatar
Re: installed new Hu and sound is screeching
Well your first mistake was clarion. Secondly does the screech get louder when you rev your engine? Check all your connections and grounds.
Old Mar 29, 2006 | 09:47 PM
LS1 RULZ's Avatar
Alternator noise will make a whistling or whining noise that goes up and down in pitch as you rev the engine. If it's a nasty screeching noise you're getting you may have a short somewhere. What did you use to connect your Clarion to the POS Monsoon amp?
Old Apr 2, 2006 | 12:44 PM
3800rs's Avatar
i just wired it up to the conector. it sounded good before i put the hu in. it seems the screech/distortion is from the driver front component speaker. it doesnt change with the rev as far as i can tell
Old Apr 2, 2006 | 01:03 PM
3800rs's Avatar
it sounds as it is comming from the tweeter but i am not positive. does it need to be adjusted ?
Old Apr 2, 2006 | 01:31 PM
LS1 RULZ's Avatar
I would re-check the wiring to that side to make sure you didn't pinch the wire somewhere and cause it to short out.
Old Apr 2, 2006 | 01:35 PM
3800rs's Avatar
will check now
Old Apr 2, 2006 | 02:17 PM
3800rs's Avatar
all wires are good behind the hu. i do also get a bass pop when i turn on/off my radio in that speaker
Old Apr 2, 2006 | 02:48 PM
LS1 RULZ's Avatar
Checking the wires behind the HU is not enough. You need to track the wire all the way from the HU to the speaker.
Old Apr 3, 2006 | 06:52 PM
VTsullyman's Avatar
Yeah soethig is pinched or has some coating stripped off somewhere. If you wanna take a slightly easyer route pick easy spots along the wire run and hook up a volt meter. That should help you tell where the trouble ares is by elimnation
Old Apr 4, 2006 | 12:21 AM
Rashiki's Avatar
Are those monsoon systems amped from the factory with an external amp?
If that's the case, you can't amplify an amplifier and you're going to blow something soon if you don't either bypass the monsoon amp or get one of those little converters. Also, you'll probably run the risk of ruining the HU as the speakers (at least in my car) were like half an ohm and matched to the stock amp. You'll smoke the amp in the HU when the speakers draw way too much current due to the small resistance.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
warmeck
Mar 22, 2015 10:28 AM
Collector Car
Jan 5, 2015 10:58 AM
squarehead
Nov 21, 2014 08:02 PM
