installed a CD player in my g/f's car(have a problem)
she owns a 2000 sentra and a lot of the buttons were broke so she wanted another factory cd player. So I found one bought it thing looked brand new. Put it in everything works fine except it gets a read error with the cd's sometimes. This is with burnt cd's and regular store bought cd's. Any idea on what would cause this read error??
Re: installed a CD player in my g/f's car(have a problem)
Originally Posted by superadobo808
The player could be dirty, get a cleaning kit and try it.
Originally Posted by Red97LT1
The laser that reads the data off the cd could be bad also.
that better not be it otherwise i'll be pissed. I wonder why it didn't work at first then would kinda work then worked good for 1.5months then just stop working. GRR i'll try cleanin it and see what happens
good luck man, tell us how it goes. You should start with the easy and cheap stuff first, then if you cant trouble shoot it, take it in, or get a new one.
Originally Posted by speed76demon
Now I don't like u
it was under warranty and I got it fixed for free,but it was only 3 months old and it started funny. It could also be a loose connection inside the radio and it makes connections at times. Hope you figure it out.
The reason I mentioned this is I had one acting somewhat the way you are explaining.
btw i'm trying the cleaner tonight
what would ya suggest if it was a loose connection inside the radio??
well I used the cleaning cd and of course it read it fine and worked. Then we put a cd and it worked for about 2minutes then it quit. Then it hasn't been able to read any cd's since. I just don't know what the hell to do
Originally Posted by blknblu
This is right, the laser could be bad, but instead of replacing the whole stereo,since you already have 2, the new and the old one, that I am assumeing are the same...just take the laser unit out of the old one and put it in the new one; if you get desperate.
