How to use this amp to its full potential?
Old Sep 17, 2003 | 09:23 PM
1KillerV6's Avatar
I'm getting this amp soon. I wanna use all 1200W which is at 2 omhs. I plan on running 2 12's to the amp. What kind of subs do I need and how to wire them?
Old Sep 17, 2003 | 11:36 PM
firebirdude's Avatar
That amp is also stable to 1 ohm. Just FYI. But to run two subwoofers at 2 ohms you will need one's that are either single 4 ohm or dual 2 ohm.
If they are 4 ohm SVC, just wire the positives together and then connect to the positive output on the amp. Then repeat for the negatives.
If they are 2 ohm DVC, wire each subs positives and negatives together. Then take one woofers +'s and wire to the other woofers -'s. Same with the other pair of +'s & -'s.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
meissen
Jun 1, 2015 07:59 AM
NewsBot
Jan 8, 2015 11:29 PM
