How often should the Cap be charged?
Old Nov 4, 2006 | 02:00 AM
19z28camaro02's Avatar
How often do i need my capacitor to be recharged? its a 1000w on a 1200w amp with 4 10" subs, 2 400w, 2 250w
Old Nov 4, 2006 | 02:18 AM
sbs's Avatar
sbs
I'd get it topped up at the same time that you have the muffler bearings changed.
Old Nov 4, 2006 | 06:43 AM
LS1 RULZ's Avatar
And don't forget to change the blinker fluid while you're at it.
But seriously.... as long as the cap is connected it IS charged.
Old Nov 4, 2006 | 01:05 PM
TheMT1's Avatar
When did they start rating caps in watts?
Old Nov 4, 2006 | 01:34 PM
JakeRobb's Avatar
Super Moderator
Since everyone else is just giving you crap...
You do not need to charge a capacitor. It's charged by the car's electrical system (battery/alternator) automatically. Its purpose is to provide a way for a lot of current to reach the amplifier quickly without the need for an alternator rated at that level of current. It's basically a reservoir. When your music demands a lot of power (typically when there's a lot of hard-hitting bass), it draws energy from the capacitor. Then, during less demanding sections of your music, the alternator recharges the capacitor.
It works pretty much the same way as a water tower. There's a pump that is always putting water in the water tower (unless it's full), but sometimes the community's water demands are higher than the pump can satisfy. The water in the water tower makes up the difference. The level goes down during high-demand periods, and the pump fills it back up during low-demand periods.
Watts = Amps * Volts.
Farads = Amps * Seconds / Volts
Technically, caps could be rated in watts if they also included a time rating (e.g. 1000w for 30 seconds). If they leave the time rating out, then they're telling you how quickly the cap can disperse energy (i.e. how large of an amp it can support), but now how deep its reserves are (i.e. how long you can listen to very demanding music).
In a car audio application, the wattage rating is more important. Even the smallest car audio capacitors (I've seen 0.25 Farad units) can store more than enough energy to provide the backup power needed.
Most car audio systems don't need capacitors. An amp rated at 1200w, assuming the rating is accurate, draws a maximum of 83 amps at 14.4 volts. Most alternators these days provide at least 90 amps, and more often 100 or more. This means that your alternator is enough to do the job, which means you don't need the cap.
Moral of the story? Sell the cap to some fool who doesn't understand and save your money for something that matters.
Old Nov 4, 2006 | 02:34 PM
GALIATHON's Avatar
Hey Jake QUESTION- If your running underdrive pulleys on a car, Would the cap help. So you dont put as much strain on the Alt??
Old Nov 4, 2006 | 04:05 PM
JakeRobb's Avatar
Super Moderator
No, a cap doesn't really help if you're running underdrive pulleys. Except at idle, underdrive pulleys have no effect on your alternator's performance. Once the revs are at, say, 1000rpm, you'll never know the difference.
A cap will only help when your system demands more current (amps) than your alternator can provide.
If you're concerned about voltage at idle with an underdrive pulley, get an overdrive pulley for your alternator (so that it spins the same speed it did when you had stock pulleys). I know that when I eventually get around to installing an underdrive pulley, I will get a kit with an alternator overdrive pulley.
If your lights dim when the bass hits on your car, get a better (higher amps) alternator. Forget about caps altogether.
Old Nov 4, 2006 | 05:48 PM
GALIATHON's Avatar
Yeah I was just wondering about that.. I do have the alt pulley also.. And my lights do dim when the bass hits.. A higher Alt is my next move.. I dont drive it much so really didnt rush 2 get 1.. Thanks 4 the info.. Always good 2 gain more knowledge
Old Nov 7, 2006 | 02:40 PM
the727kid's Avatar
CAPS ARE A WAISTE OF MONEY
They do nothing put a strain on your alternator. They let their energy for a large hit and then must re-charge putting strain on the alt.
Do your Big 3 and run 0 gauge to the distro block and you will have MUCH better results than a Cap could provide.
Old Nov 7, 2006 | 03:01 PM
chris96camaro's Avatar
I would agree with doing the big three, thats the best way to help your cars electrical system, along with maybe a ~200 amp alternator, depending on what you are running. And from my experience, a cap is a huge waste of money.
Old Nov 7, 2006 | 03:08 PM
the727kid's Avatar
I see I'm not the only one on here with some audio knowledge.
BTW 200amps alts are about $250.
Old Nov 7, 2006 | 09:00 PM
If anybody is interested in a new alt., this is a good place to get them...
http://www.mean-green.com/products/alternator.html
Old Nov 7, 2006 | 09:19 PM
the727kid's Avatar
I'm actually going to get a KnuKonceptz one.
Old Nov 7, 2006 | 09:51 PM
Well then consider that link for those who aren't as well versed in car electronics as you and I..
Old Nov 7, 2006 | 11:05 PM
the727kid's Avatar
Lol tru.
