how to hook up amp on stock HU
i have a rockford punch 100a that i want to put in my car along with two pioneer 12's how do i go about hooking up the amp with my stock hu? should i tap into my rear speakers or is there some kind of output on the radio? and where to hook the remote wire?
Re: how to hook up amp on stock HU
you can hook a hi/lo converter up to the speakers to give you the rca connections you need. As for the remote wire you shouold be able to find a 12v ignition wire under the dash usually a pink wire in the ignition harness under the dash.
NewsBot
Jan 8, 2015 11:29 PM
