how do i install a remote start onto a manual tranny?
Re: how do i install a remote start onto a manual tranny?
Get a starter made for manual trannies. When you shut the car off, it'll go into reservation mode. Meaning it'll run with the key out and when you close the door, it shuts off. That's how it knows it's in neutral.
My recommendation: http://www.compustar.org
Unplug the plug in the clutch switch, splice the wires together and that shoud be it. You can try this link but that's what I gathered from the info here: http://web.camaross.com/forums/showt...ghlight=bypass
If you ever take that thing in to a shop once you've disabled safety make sure you tell them that it had that disabled !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ha I Can See It Now When Your Start It Up And It Jumps Forward Adn Drives Down The Street If Tou Put It In Gear And Forget To Take It Out But I Wouldnt Do It Because Its To Much Of A Risk To Forget To Take It Out Of Gear And It Runnin Into A House Car Or Even A Person So I Wouldnt Do It Plus Its Bad On Yer Starter
importkiller94
Jan 17, 2015 09:03 PM
Jul 4, 2005 05:00 PM
