CamaroZ28.Com Message Board
-   Car Audio and Electronics (https://www.camaroz28.com/forums/car-audio-electronics-12/)
-   -   how did you connect to your side terminal battery?? (https://www.camaroz28.com/forums/car-audio-electronics-12/how-did-you-connect-your-side-terminal-battery-6799/)
redz_02 Jul 21, 2002 08:27 PM
Well usualy i would just get an o connector and then bolt it down, but my current system is using a 2 guage from the batterie to a 140 amp breaker. I plan on doing the same to the ground to eqaul it out to the frame. For big amp installs, what did you do.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift knob, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
LS1 RULZ Jul 22, 2002 06:25 AM
I used a sidepost terminal adapter and large gauge crimp-on ring connectors.
DrMilhouse Jul 22, 2002 09:26 AM
I'm guessing that if you're running 2 guage, your system is probably big enough that you're going to want a bigger battery to begin with. In that case, I'd recommend what I did which is just get a red top optima and use the top posts for your stereo and the side posts for the rest of your car.
HTH
99 Z28 LS1 (broken with 383 replacement in the works) M6
stereo pics FOR SALE!!!
Moderator at CamaroVsMustang.com
Send while you can!
rthompson Jul 24, 2002 09:42 AM
<font face="Verdana, Arial" size="2">Originally posted by DrMilhouse:
HTH
</font>
Why red top? Optima suggests the Yellow top for use in car stereo, and using a Red top in audio applications voids the warranty on it... read the FAQ on the optima site, it is very informative.
Soundillusions.net
The ultimate in caraudio.
Sony, Arc Audio, Infinity, Adire Audio, A/D/S
