Hi-amp alternators
Old Jul 30, 2003 | 07:43 AM
robtombie's Avatar
Hi-amp alternators
Where's a good place to get hi-amp alternators? I'm looking for one that puts out atleast 100+ amps
Old Jul 30, 2003 | 12:10 PM
LWillmann's Avatar
Depending on the year and model car you have it might already put out over 100 amps. The Z28, Formula and T/A from 93-97 had the CS-144 alternator which puts out 140 amps. The alternator on my wife's 2001 Camaro V6 puts out 105, and it's stock.
Now, there are numerous places to get upgraded, high-output alternators.
Mr Alternator and Powermaster are just two. One I recommend is a guy named Dominick Irragi. He builds them himself. He's an SPL stereo competitor and runs his own stuff. Also, many people across the country use his alternators. Check him out: dominick@tds.net.
Old Jul 30, 2003 | 12:24 PM
BoulderCamaro's Avatar
Precision Power will build you one and that would probably be the best you could buy. If you are going to run a serious application you should probably get a larger gauge wiring for it.
Oh...you should use some unregulated amps if you pick up a high output alternator - you'll be pleased!
Old Jul 30, 2003 | 08:06 PM
firebirdude's Avatar
I second and third dominick. I'm running his alt now. Wonderful little piece. They key thing to look for when buying a H/O alt for dailey driver is how many amps it outputs AT IDLE!!! That is key. Don't forget that.....
??? We're talking power supplies here correct? Last time I checked my high output alt still outputs 14.4V, same as stock.
Old Jul 31, 2003 | 07:14 AM
robtombie's Avatar
I should be able to check my currant alternator amp output with a Digital Multimeter shouldn't I? Thanks for the replies.
Old Jul 31, 2003 | 07:52 AM
LWillmann's Avatar
I don't know if most multimeters can actually test amperage. You might have to use an ammeter for that.
Or take it to Autozone, they should be able to tell you.
Old Jul 31, 2003 | 08:01 AM
LS1 RULZ's Avatar
A regular Joe multi-meter aint gonna cut it. You need one of these.
Old Jul 31, 2003 | 01:04 PM
MANY places will do it for free. Auto Zone, Pep Boys, etc....
Old Jul 31, 2003 | 01:38 PM
LS1 RULZ's Avatar
Thats true too. But I love having a reason to buy another tool.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
