Help with stereo wiring
Old Mar 1, 2005 | 10:30 PM
dabez1's Avatar
I know this doesnt have anythign to do with f-bodies but i need to figure out where the REMOTE wire that goes from the back of the stereo to the amplifier. This is the stock stereo of a 99 Tayota tacoma.
Theres so many damn wires in the back of the stereo. Any diagrams?
Old Mar 1, 2005 | 10:56 PM
Re: Help with stereo wiring
Doh! Isn't there a Tacoma forum somewhere?
I just don't get it when someone says they know they are not supposed to post a question here and do it anyway.
Is there a high percentage of f-body and Tacoma owners? I don't know.
Old Mar 2, 2005 | 03:04 AM
billsbird's Avatar
...go to the service deptment at a Toyota dealership.... Or parts....
They will know.... or I read that Toyota is recalling 22,000 Tacoma's. May be
the recall is for a missing stereo wire???? zzz
Old Mar 3, 2005 | 11:39 AM
baxter96720.cz28.com's Avatar
A lot of the time the remote wire is blue. I dont know if that will be of any help to you or not. Good luck.
Old Mar 9, 2005 | 12:05 AM
Javelin3o4's Avatar
http://www.precisionautosound.net/toyota-2.html
87-Newer diagram, colors may have changed as far as sthe diagram shows but it should use the same plug unless its amplified then it may just have 1 plug in the back that goes down to the factory amp that is uaually behind the radio console but would have the 2 standard toyota harnesses plugged into it just follow that one plug down if its like that. I would probably use pin c for the remote which should be ignition.
mattstrike
Mar 11, 2015 07:33 PM
raroz28
Mar 10, 2015 11:18 AM
x7x7
Aug 15, 2002 06:49 PM
Omega9
Aug 2, 2002 12:33 AM
BOOGER
Jul 25, 2002 02:42 PM
