headlight problem
Old Mar 27, 2005 | 07:36 PM
BigggD222's Avatar
headlight problem
Well the other night I noticed my drivers side headlight was out, so when driving at night I just used my brights until the local Advanced Autoparts recieved some replacements for me. After installing the new Sylvania Silverstars into both the drivers and passenger side, I took the car for a test drive to see how well the new headlamps worked. As you know they worked a lot better than standard halogens, but on my way back to campus my drivers side headlight went out again. So I turn on the brights......same thing happened the bright worked for about 5 minutes then went out!!!! I checked the fuse relays and both fuses are fine, all grounds are fine, the only thing I have not done is take the light out and see if it works by connecting a positive and negative to the battery.... I also do not have one of those electrical indicators (can't think of the technical name of it right now). Anyone have any ideas of what could be wrong?? Any of you F-body guys ever have this problem?
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
