Head unit help
Old Nov 7, 2006 | 01:54 PM
squints88's Avatar
Head unit help
Well my Delco Bose head unit is giving me some problems, its flickering on and off. I'm pretty sure it's the head unit and not the wiring as I have been in there a few times and havn't found anything loose.
I really don't know anything about car audio, and I'm not going to pay someone to wire a new head unit for me. My question is weill I need some type of dash adaptor to house the new unit? Also do I need some sort of adaptor for the wiring harness or can I get one that plugs right in. Any help would be appreciated!
Later,
Ryan
Old Nov 7, 2006 | 02:25 PM
the727kid's Avatar
Well....I am completely engine illterate but VERY knowledgable in car audio so I'll help out round here lol.
Anyways, you need a dash kit, a wiring harness, and a antenna adapter. All can be had for around $20 shipped on ebay. The antenna adapter you just plug in into the original one and then plug the other end into the new HU. The wiring harness, you just match colors and crimp the wires together. And the dash kit, well the one I ordered didn't fit properly it had a weird thing sticking off to the side, i just broke it off and it fit good.
Old Nov 7, 2006 | 05:06 PM
squints88's Avatar
damn I gotta splice all those wires that sucks haha, thanks for the help though man, I'll let you know how I make out
Old Nov 7, 2006 | 06:30 PM
moparman's Avatar
DON'T cut any wires. Use the wiring harness.
Old Nov 8, 2006 | 07:46 PM
squints88's Avatar
ok well I tried to get everything in today..ran into a problem.
I bought a sony head unit, wiring harness, antenna adaptor, and I was tolf I needed a "bose system interface" to get it to work. I wired everything together and it turns on but says "failure" meaning the speakers or amp was wired incorrectly. Everything is right though...
The only thing I can think of is that the wire for the amplifier coming from the head unit is not connected. There is nothing to connect it too...
Will I have to find the amp wire and connect it? I have no idea where the bose amp is...let alone how it is wired so again, any help would be great!
Old Nov 8, 2006 | 10:48 PM
the727kid's Avatar
Get teh interface..
Old Nov 9, 2006 | 05:45 AM
squints88's Avatar
yea I got the interface when I bought everything else. Everything is wired correctly from what I can see, all connections are soldered neatly..but its not working. Like I said there is an amp aire coming from the head unit harness that was I had to leave disconnected, could that be it?
Old Nov 9, 2006 | 11:19 AM
the727kid's Avatar
The blue/white turn on? That should only be for an aftermarket amplifier.
Old Nov 9, 2006 | 02:01 PM
squints88's Avatar
yea its blue and white, thats the only thing I could think of..I have no idea why its not working haha
Old Nov 9, 2006 | 03:56 PM
PentaVolvo's Avatar
try wiring without the interface
Old Nov 12, 2006 | 02:26 PM
squints88's Avatar
ook..update..
I nixed the interface and the guy at best buy told me to ground the negative RR and LF wires and wire everything else normally without the interface. Now my radio works..but it won't play a CD. excellent. I then tried to just wire it straight through without grounding the two wires and only the radio worked again but this time it only came through the rear speakers it sounded like.
Does anyone know how to get this thing to play a CD? Apparently somethings right if the tuner works..
Old Nov 12, 2006 | 08:58 PM
the727kid's Avatar
If it don't play a CD that's an issue with the HU, not wiring.
Old Nov 13, 2006 | 11:22 AM
squints88's Avatar
No it plays the CD, just no sound comes out, sorry. It still says "failure," meanin there is a wiring error.
Old Nov 13, 2006 | 05:53 PM
the727kid's Avatar
Take it out, make sure everything is wired securley. And if it's still doing it I would say go to Circuit City, buy a cheap CD player and see if it that works. (they got a 30 day return policy)
Old Nov 13, 2006 | 09:41 PM
squints88's Avatar
i got it. I spliced the blue wire for an aftermarket amplifier into the power antenna wire and boom, perfect. Everything functions, including fade, balance, and all that good stuff inlike some peoples. im so glad to have a radio again!
