Guide to make a stealthbox outta fiberglass
Old Jul 21, 2005 | 12:15 AM
pHEnomIC's Avatar
I saw a guide on how to make a stealthbox on our cars. I believe it was out of fiberglass. Does anyone know the link to the site, can't seem to find it.
Also, i believe i can make a stealthbox for my 12 inch kicker competition but, do you think the box volume will be good enough to make good sound?
Old Jul 21, 2005 | 09:35 AM
shouldaboughtthez's Avatar
Re: Guide to make a stealthbox outta fiberglass
I think the air space for a 12" stealthbox would be a little on the smal side. The air space in the stealthbox is like .7 cubic feet.
I have a link that tells you how to make fiberglass boxes, not stealthboxes.
http://web.njit.edu/~cas1383/proj/main/index.htm
Old Jul 21, 2005 | 01:02 PM
johnnyb's Avatar
i saw the guide that you speak of. i think it is bookmarked on my other computer. i will get back to you later
Old Jul 21, 2005 | 01:06 PM
DarkHorse's Avatar
Good stuff - post that link if you can. This can also be made of wood correct?
Old Jul 25, 2005 | 09:49 AM
johnnyb's Avatar
http://www.fbodyaudio.com/articlevie...tealthbox.tech
Just found it and i tried to pm you but your box is full!!
Old Jul 25, 2005 | 02:40 PM
pHEnomIC's Avatar
Yeah thats it, thanks man, you the man!
Old Jul 27, 2005 | 11:48 PM
Austin96Formula's Avatar
is that the only fbody stealhbox writeup there is?
Old Jul 28, 2005 | 02:02 AM
pHEnomIC's Avatar
I ended up doing mine on the drivers side outta wood. Do not attempt to make it out of wood. In the end, it is probably better but it is insanely hard. IT is the oddest shape in the world. I cut at least 20 pieces to put together to avoid stuff in the way.
At this point, i cant fit it in there anymore so i need to redo a part and it is leaking air a bit. Ill get it fixed but its a pita.
Old Jul 28, 2005 | 03:12 AM
Yeah.. I wanted to glass a pass side box. I'm gonna design one, but it's not gonna be the typical look of the one link posted, so I'll write up a lil something about it. But thats down the road. I first have to build new door pods for some 8" drivers, then build up my kick panels for a 4" set, then I can think about the box an amp rack. Ugh.. Sooo much fiberglass work... And I really hate working with it.
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
luvmyz28
Sep 15, 2002 04:36 PM
Silver99
Sep 8, 2002 11:49 AM
ChameleonGreen
Sep 2, 2002 05:15 AM
ericinsd
Jul 31, 2002 02:15 PM
