Ground Loop Isolators
http://www.crutchfield.com/cgi-bin/S...=1&cc=01&avf=Y
PAC COF-2
Here's a little thing I found. Dunno it it will help any though
PAC COF-2
bad ground
Usually high level inputs never have noise. Try running a 10ga ground from your radio to the amp in question. Also turn the amp down. With high level inputs there sould be no reason for gain to be over even half. If you are running more than one amp make sure the grounds are either at the same point or you connect them together w/10ga wire. Try fixing the grounds before you buy anything. I have seen these ground loop isolators make the noise worse and also some systems have lost bass because of them.
Re: Ground Loop Isolators
Originally posted by snorkelface
Are these available if you're using speaker-level inputs?
I know, I know, but it's just a temp fix.
Re: bad ground
autoxr166
Sep 25, 2015 04:21 PM
tommalcolm
Sep 11, 2015 03:39 PM
