Good Ground Point for Rear Mounted Battery?
Old Apr 29, 2004 | 01:40 PM
Birdie2000's Avatar
I'm relocating my battery to the spare tire well in my 94 Formula. I used to have an amp back there and I grounded it to the bolt that used to hold the rear seatbelt in place on top of the rear wheelwell, and it worked just fine. I am wondering if this bolt is adequate for grounding the battery to, or if I should find somewhere else. It's a nice, convenient spot that's inside the car and completely hidden, so it is ideal in my mind as long as it'll make good contact. Thanks in advance.
Old Apr 30, 2004 | 06:59 PM
97droptopZ's Avatar
Do you have a Digital Multimeter?
Check the resistance from this ground point and your negative battery terminal. If it is 0, it should be sufficient.
Make sure all the paint around it is scraped off too.
HectorM52
Jul 30, 2017 11:46 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Jazsun
Dec 29, 2014 12:14 PM
Sarahrope64
Nov 27, 2014 11:17 AM
