Front speakers in a 94' Camaro z28
Old Apr 15, 2010 | 08:46 AM
englundjd's Avatar
ok im tearing into the sound system and replacing all the speakers, i got the back ones just fine but it seems ill have to take the inside of the doors off to get the front ones out, i dont know the stock speaker size but someone stuffed alpine 6 & 1/2" speakers in there and there shot ....can someone tell me how to get the inside panels off both sides, i just want to know im doing it right so i dont mess it up.
Old Apr 19, 2010 | 11:24 AM
Chevyssoccer's Avatar
Put the window down. If you have manual windows you have to remove the crank. remove the plate that the power locks switch is on. there is a screw behind it. There are three or four larger screws on the underside of the arm rest and the bottom of the door pocket. The lock slide (orange/black plastic) unclips from the rod. and its easier if you pull the mirror triangle off. Then just lift straight up. Getting back on is a little tricky to line up all the catches, especially if the speakers are a little taller.
Old Apr 23, 2010 | 08:21 AM
englundjd's Avatar
alright thanks for the information
CamaroHeed
Mar 18, 2020 09:50 PM
siguy
Nov 27, 2014 10:07 AM
carcrazyQT
Sep 3, 2002 02:51 PM
Mad_Ice
Jul 29, 2002 09:44 PM
MilkyClr69
Jul 28, 2002 02:51 PM
